FFox 116 freezes on iPhone 8
  • 1 antwoord
  • 0 hierdie probleem
  • 12 views
  • Laaste antwoord deur Paul
Hello Since the release of 116 for iPhone, my iPhone 8 freezes. I have to switch the phone off and reboot it. Only for it to occur a few minutes later. I know from the comments on the App Store that I’m not the only one.
I’m running iOS 16.6, with around 21GB of free space.
Thanks for your prompt attention. I’m having to use the G**gle app to get round this problem, which doesn’t sit well with me.
Jan
Hello Since the release of 116 for iPhone, my iPhone 8 freezes. I have to switch the phone off and reboot it. Only for it to occur a few minutes later. I know from the comments on the App Store that I’m not the only one. I’m running iOS 16.6, with around 21GB of free space. Thanks for your prompt attention. I’m having to use the G**gle app to get round this problem, which doesn’t sit well with me. Jan
Hi
I am sorry to hear that Firefox for iOS is crashing. I hope that we can help resolve this for you. Before following the steps below, please make sure that you have updated both your iOS device and Firefox for iOS to the latest versions available.
As a first step, close down many of the tabs that you have open to as few as possible. Does this help reduce the incidence of a crash?
If this does not resolve the issue, open the iOS Settings app, select General then iPhone Storage. Find Firefox and select Offload App. Does this help?
Failing that, we will need to look into this in more detail with some logs from inside your copy of Firefox for iOS. This article will walk you through getting both crash logs and Firefox logs. When you have them, please file them here (a GitHub account is required) so that our developers can look into this further for you.
I hope that this helps.
